Detailed tech specs on Raptor?
troverman
NH
Just bought a 2018 Raptor yesterday after owning 5 Super Duty pickups.
What I'm looking for is detailed info on the Raptor. I want to know more info on what is different between the Raptor 3.5L and the pickup 3.5L. Any transmission differences? The transfer case...is the "4A" function the same as it would be on a Lariat F-150? I realize the 4H and 4L modes physically lock (kind of like the transfer case in an XL or XLT F-150 which don't have the 4A mode). Anything beyond that? Is the low ratio the same 2.64:1 as an F-150?
I'd like info on the frame differences. I understand the Raptor has a unique frame. Is it essentially an F-150 frame with some thicker sections?
I've read the rear axle on the Raptor is 35 spline whereas on the F-150 it is not. Are the axles physically wider? Is the front diff / axle the same?
How many amps is the alternator? 220A like an F-150?
Thanks in advance
T
troverman
NH
Thanks for the link, BurnOut.
What I gleaned was the following:
-Frame difference is limited to shock mounts (+50% stronger rear and +25% stronger front plus higher mounting location for both) and additional weldments for strength. Otherwise, the frame is an F-150 frame.
-Axles are the same except the rear axle uses 35 spline axle half-shafts compared to standard F-150 shafts.
-Front hood and fenders are composite. Knew the fenders were; did not know the hood was.
-The HO 3.5L EB uses larger turbos with a little higher boost plus electronically controlled wastegates instead of pressure-controlled. The engine uses dual electric fans instead of the single electric fan on standard F-150 EB motors. The 2-piece oil pan and "low structure" is unique to the Raptor.
