Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 2 (2017+) Ford F-150 Raptor Forums > Ford F-150 Raptor General Discussions [GEN 2]
Clunk/Thumping noise on startup?
This is a discussion on Clunk/Thumping noise on startup? within the Ford F-150 Raptor General Discussions [GEN 2] forums, part of the GEN 2 (2017+) Ford F-150 Raptor Forums category!
Anyone else notice this...when I start my Raptor (mostly when it's already warmed up), I sometimes get a "Thump or ...
Old 08-12-2018, 02:19 PM   #1 (permalink)
HotLap's Avatar
Default Clunk/Thumping noise on startup?
Anyone else notice this...when I start my Raptor (mostly when it's already warmed up), I sometimes get a "Thump or Clunking" noise right when the engine catches and starts. doesn't sound terminal or anything, but have noticed it on several occasions now.
Did a search and nothing came up, anyone else notice this?
PS It happens so quickly, right at startup, it's hard to get a handle on what it could be. Doesn't sound like an exhaust noise...
2018 Magnetic/802A/CF Interior/Tech Pkg./Moonroof/Tailgate Step, FRL 6 Light bracket w Rigid D Series Pro Floods/Spots, Hellwig rear sway bar, Ford Performance rear diff cover, more to come...
HotLap is offline   Reply With Quote
Old 08-12-2018, 05:15 PM   #2 (permalink)
first 5 mins, will hear roughly 5 metal clunk, being told it's normal.
cao0215 is offline   Reply With Quote
Old 08-12-2018, 08:48 PM   #3 (permalink)
Junior Member
Same here. Never does it cold, only hot. Real quick bang and that's it. Mines an 18 with about 5k on it
2018RubyRed is offline   Reply With Quote
Old 08-13-2018, 11:22 AM   #4 (permalink)
I get that too. Always thought it was the AC compressor clutch engaging. I could be wrong though.
jabroni619 is offline   Reply With Quote
Old 08-13-2018, 01:19 PM   #5 (permalink)
HotLap's Avatar
Thanks guys, always good to hear it's likely normal and others have heard it as well. I agree it doesn't sound terminal or anything. Mine's not likely the AC compressor as I generally don't run the air, almost always just have the windows down. I'll keep an "ear" on it and post back should anything change. Thanks!!
Old 08-14-2018, 04:52 PM   #6 (permalink)
rtmozingo's Avatar
These trucks are uniquely noisy, but in a lot of cases it doesn't seem to be anything that causes problems. I've had this ticking noise since 11k, and can't locate the source. It has not caused any problems, so I've mostly forgotten about it.
https://www.youtube.com/watch?v=8rTI77WZ5js
rtmozingo is offline   Reply With Quote
Old 08-14-2018, 06:27 PM   #7 (permalink)
Junior Member
It's normal, it's caused by slack in the drive shaft when starting the truck warm. My 2018 do this from day one and I did some extensive research. Very common in the regular F150. If you search cluck noise when starting warm F150 in google you will find very clear explanation as to why there is slack in the drive shaft. I was so worried when I first got my truck I spent two days reading this stuff. Funny there is not much in the raptor forum on this, just in the F150 forums. Hope this helps.
gobie18 is offline   Reply With Quote
Old Yesterday, 07:29 PM   #8 (permalink)
Junior Member
Now that you mention the driveshaft slack it does make sense. Happens when I'm on the hill, set the parking brake in neutral to let it catch the drums and then put it in park.
Startup thrashing noise DrumReaper Ford F-150 Raptor General Discussions [GEN 2] 56 09-18-2017 06:20 AM
Noise from engine after startup slosvt Ford SVT Raptor General Discussions [GEN 1] 9 06-05-2017 01:11 PM
Clicking/Ticking Noise on Startup svt_ivan Ford Raptor Audio/Video/Electronics Forum [GEN 1] 2 01-18-2017 10:35 AM
Thumping/Wind Noise at high speed from sunroof BigGriff023 Ford SVT Raptor General Discussions [GEN 1] 6 11-06-2016 05:19 PM
High fan noise at startup idle goinsvt Ford Raptor Problems and Questions Forum 8 07-28-2013 11:15 AM
