Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 2 (2017+) Ford F-150 Raptor Forums > Ford F-150 Raptor General Discussions [GEN 2]
ceramic coating
This is a discussion on ceramic coating within the Ford F-150 Raptor General Discussions [GEN 2] forums, part of the GEN 2 (2017+) Ford F-150 Raptor Forums category!
Like Tree6Likes
Old 05-15-2018, 03:10 PM   #11 (permalink)
maxemus's Avatar
Originally Posted by BangBang View Post
Someone educate me;
Is Ford paint not up to snuff that it needs PPF and/or ceramic coatings?
What is the average cost of PPF?
Itís got nothing to do with Fords painting. Itís level of protection and convenience for those that care to keep their vehicle at a higher level of cleanliness or ease thereof.
maxemus is offline   Reply With Quote
Old 05-15-2018, 03:55 PM   #12 (permalink)
BangBang's Avatar
Aaaaah! Glad to know it's not poor paint quality.
BangBang is offline   Reply With Quote
Old 05-15-2018, 04:57 PM   #13 (permalink)
rtmozingo's Avatar
Someone educate me;
Ford paint is not really any different than any other OEM paint.
Coatings just make it easier to clean, same way a good wax or sealant does (but a coating much more so).
PPF actually protects the paint, it is the classic clear bra. Takes the damage so the paint doesn't.
rtmozingo is offline   Reply With Quote
Old 05-16-2018, 10:26 PM   #14 (permalink)
Junior Member
has anyone tried IGL Kenzo?
0r30 is offline   Reply With Quote
Old 05-17-2018, 12:33 PM   #15 (permalink)
ewm98's Avatar
Junior Member
I have it on my black 7 Series and Raptor. It makes cleaning both very easy. I was skeptical at first since the price was much higher then coatings but compared to other coatings I have worked with it does seem to hold up the best.
Bhollier likes this.
2017 Magnetic 802A Supercrew W/ Tech package, Eibach Pro Lift Springs, Method MR301 (Machined)
ewm98 is offline   Reply With Quote
Old 05-17-2018, 02:23 PM   #16 (permalink)
Junior Member
I have cquartz on mine. Likely going to go kamikaze before the winter
bryan_nj is offline   Reply With Quote
Old 05-18-2018, 07:23 PM   #17 (permalink)
Originally Posted by Bjoeaull View Post
I put Adams ceramic coating on mine a month or so ago after I polished it. Pretty serious protection. I also put coating on the rims and trim coating on all plastic pieces. I hope to get two years out of it. There are longer duration coatings out there, but Adams is pretty user friendly.
Pretty reasonably priced too correct? I hear some guys getting ceramic done for 1000 and this is DIY for like 150$? Not sure the real differences ina professional shop and this DIY ceramic coating but..
Also can ceramic coatings be removed and redone if they are a Diy take home application ?
misuracaf10 is offline   Reply With Quote
Old Yesterday, 12:43 AM   #18 (permalink)
Junior Member
Surface must be machine polished to remove ceramic coatings and it can be very hard to identify when the coating is gone and your removing clear
misuracaf10 likes this.
Megabass is online now   Reply With Quote
Old Yesterday, 10:29 PM   #19 (permalink)
Junior Member
Its priced well, but the money you are saving by not having it professionally done is really just the labor. It takes a lot of time and prep to do a ceramic coating correctly. Wash, clay, polish, polish some more, prep wipedown, ceramic coat, then ceramic boost.
They can only be removed by machine polish, so thats why prep and careful application are critical. The difficulty removing really just says a lot about how durable of a coating it really is....
If you are still curious, I'd recommend going to the Adams site and learn up on their process, should be some videos. youtube is a great resource too
Bjoeaull is offline   Reply With Quote
Old Yesterday, 11:04 PM   #20 (permalink)
Default ceramic coating
Thanks for the tip. If the Adams ceramic coat will last as long as the professionally applied one then that would be awesome. Someone said the DIYs May only last a couple years... so I was wondering if you had to reapply it or if you had to remove it all and then reapply? I guess I wouldnít be able to tell when itís worn off anyways.
Also it seems that most of that prep could/Should Be done when the truck is brand new and would make it much easier on you then to wait after the truck has gotten dirty and really needs a more thorough prep with a clay bar wax and polish. Leaves less room for error when itís brand new and you have to DIY.
I still obviously need to do my homework on it a bit more
Ceramic coating Spartan1 Ford F-150 Raptor General Discussions [GEN 2] 75 03-26-2018 07:44 AM
Completed ceramic coating Wassy Ford Raptor Exterior Forum [GEN 2] 2 03-14-2017 01:55 PM
Adam's ceramic wheel coating kit dingo Adam's Polishes 12 02-22-2017 12:23 PM
GEN 2 Ceramic Coating ldhacker Ford Raptor Exterior Forum [GEN 2] 20 02-12-2017 06:37 PM
Ceramic paint coating. Digger Ford Raptor Exterior Forum [GEN 2] 29 01-29-2017 05:40 PM
