BF GOODRICH 37s
KWT
Gentlemen,
I want to install BFgoodrich K02 37’s on my 17 raptor, did anyone do it?
Will it cause rubbing?
And if it does, what should I do for them to fit?
Thanks in advance.
waddellw
Mississippi
On the Gen 1, it required a lot of modifications, on the Gen 2 I think a level would do the trick from what I've read, but as the guy above pointed out there's a lot of info out and about on the topic already. Good luck!
ChevyChad
The offset of your wheels will greatly affect the amount of interference you will have. I had a gen 1 with 0 offset wheels, 37's and mid perch and I was able to get away with minimal trimming. My 17 with 0 offset wheels and 37's required significantly more clearancing and I have the full 2.25" icon front leveling kit installed.
AndysLog
Moro IL
you can daily 37s on gen1 with zero mods.
Aaron
Meme Corps Commandant
WA
This is the worst representation of showing what it takes to run a 37, yet you continue to post it. Do you have an explanation as to why you trimmed so much that includes actual words and not another picture?
It's not his...he doesn't do mods that don't directly bolt on or require adhesive. He just saved this pic from someone else's thread. Someone else who may have done it wrong, but had the balls to ACTUALLY attempt it. Jake wants to slam on the guy over and over.
