I ve been seen engine light on for a whole day and off for 3 to 4 days, then rotation back and disappeared. Back to dealer, they can not find the wrong code in my truck
Get an OBDII wifi or bluetooth reader on amazon for $12ish and grab an app like OBDII Fusion or Torque and then the next time you get the light you can read the code immediately and find out what it is.
This is $20-30 that everybody should spend on their truck IMO
Shouldn't the code stay in memory even after the CEL goes off?
Some are soft codes that do not store in memory. Misfire codes are an example of this - they are cleared on each ignition cycle.
I ll get one just in case to check it immediately when it is on. Thanks
