KentSD
www.BookBaja.com Baja yacht Support
Got the truck back from the Dealer Monday after been in and out of the shop fixed all the noises and problems. North county Ford did a great job making sure it was in perfect order.
Took off Thursday to Loreto at 4am-
Running strong and smooth no mechanical issues. At mile 450 i got out just to check out lugs and tires as i usually do and sure enough i heard some air rushing out of passenger side left (BFG 37 D load) (They do not make E load T/A in 37 unfortunately) The 35" Spare didn't have a working valve stem so thank you Ford for that. My ******* for not checking it though... So I was loosing about 1 PSI per 3/4 mile i got 30 miles down road before i was at 20PSI - Fellow Raptor went by and had a nice air compressor in the back and loaded me up to about 55 PSI that got me to Guerrero ***** on 20 PSI again wherre i patched it up at a local shop for an entire $6 bucks then got to Loreto...
Way home i decided NOT to take the fun ways and did the road the entire way.
drove a lot slower because i had a patch job on there....and boom my luck gushing air out the driver side rear now... Couldn't believe it. Got out and jumped right back in the truck as i knew i was only 3 miles to Cocos Corner. Got there with 10PSI --- Im pretty much screwed... Ghetto rigged the shit out of the spare 35 valve stem and got me home limping to San Diego last night... All in a days work!
These D load tires are the worst! Bring back the E load BFG!!!!!!
Loreto and San Cosme epic as usual though so still had another epic trip
KentSD on insta for some more shots and videos
