2H vs 4H alignment.....
shapiroeric
Longmeadow, MA
Truck runs fine in 2H....when I out it into 4H there's a significant pull to the left....I'm assuming there's an alignment adjustment needed but didn't know it could be that off when 4WD is engaged.....
shapiroeric
shapiroeric
Longmeadow, MA
Has nothing to do with alignment, the pull you are experiencing is the drive train working.
Don't use 4H on dry pavement. Use 4A if you want extra grip on pavement.
Thanks. I first noticed it when I went to “Wet/Ice” mode and it went to 4A. Pulled initially then was fine. Played around with it and put it into 4H. Then noticed the pull. Thanks for letting me know it’s normal operation....
aschiller98
It has to do with the torsen front diff, it causes the truck to pull pretty significantly under power. It changes the steering feel quite a bit too
