Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Hi All---2018 Ford raptor owner , loving it...noticed this rotor (passenger side front...looks like pad is not touching entire rotor....other side from rotor is normal....any ideas?
Cheers
Rotor pictured is another vehicle I own...not the raptor
Further inspection needed... either a valley in the rotor where the rust is, or the pad is jacked up and not making contact with the rotor. Either way, I'd head to a dealer...
Sounds like your pads are not floating back and forth evenly top to bottom. I ran into this on a 2013 Explorer. I had to buy new caliper brackets and spring clips and install. The pads float correct now. I kept the old and ground that area back down. Looks like I will be swapping brackets at each brake job.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
