Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 2 (2017+) Ford F-150 Raptor Forums > Ford F-150 Raptor General Discussions [GEN 2]
2017 Raptor Transmission Slip & Overheat
This is a discussion on 2017 Raptor Transmission Slip & Overheat within the Ford F-150 Raptor General Discussions [GEN 2] forums, part of the GEN 2 (2017+) Ford F-150 Raptor Forums category!
Originally Posted by KyekyeG The dealer had verified high temps and limp mode codes. But they can't figer why. But ...
Like Tree3Likes
Old 12-17-2017, 11:28 PM   #11 (permalink)
Ltl6pack's Avatar
Originally Posted by KyekyeG View Post
The dealer had verified high temps and limp mode codes. But they can't figer why. But to fill it back up with fluids and call it quits.
They thought it was a bad computer that time and replaced it.
Look at the lines going to and from the cooler. This is a photo of what you might fine.
Ltl6pack is offline   Reply With Quote
Old 12-19-2017, 03:50 PM   #12 (permalink)
My plastic pan was leaking (yes the trans pan) I had the gasket replaced and my trans started doing the same thing. Once temp got over 210 it would start shifting hard and all that. The dealership contacted a ford tech and after a week or so determined it was either under or over filled. Iím not a tech or great mechanic but was told the Fluid would foam if not filled correct. When mine would overheat I could stop the engine for just a few minutes and when turned back on it would immediately cool down. It seems to be fixed now. Good luck.
Piranharaptor is offline   Reply With Quote
Tags
bbb, overheat, slipping, transmission
[COOL VIDEO] 2017 Ford Raptor 10-speed Transmission Assembly Predator Ford F-150 Raptor General Discussions [GEN 2] 0 10-16-2017 12:14 PM
Expected Gas Mileage for 2017 Raptor? (10-Speed Transmission) BlackReef Ford Raptor Engine Discussion and Performance Mods - 3.5 Liter EcoBoost V6 [GEN 2] 118 10-15-2016 08:48 PM
GEN 2 2017 Raptor And Camaro ZL1 Use Same Transmission PacificWheel Ford Raptor Engine Discussion and Performance Mods - 3.5 Liter EcoBoost V6 [GEN 2] 8 04-24-2016 03:02 AM
New Limited Slip Differential coming for the Raptor front end. Chrisandalex1 Ford SVT Raptor General Discussions [GEN 1] 19 08-01-2012 11:56 AM
TSB 11-5-7: 2011 Ford Raptor Driveline Clunk or Chirp/Slip/Bump BigJ Ford Raptor Problems and Questions Forum 0 05-26-2011 11:48 AM
