I just made this video...enjoy, hopefully this will be useful for several of you on here that are looking to install the RPG spring collars on the 2017 Ford Raptor
https://youtu.be/EnL34-Eb2fM
Very nice, well put together video.
Do you happen to have the torque specs of the bolts removed? Also, was an alignment needed after the install?
I dont at the moment but I will try and get those for you.
I didn't need an alignment and according to the instructions in the RPG kit for the 1.5s you will not need an alignment.
I'd disagree. Anytime you change the suspension, an alignment is recommended. I did the ICON AAC and while it increased the height 1.75" as opposed to the 1.5" from RPG, the result was the camber was out by 0.5° and toe was out by 0.75.
