10 speed Transmission lights
Ashton
Not sure if this is something new I found (I did do a search) In normal drive mode I was cruising a 60 mph and I was watching my 10 speed transmission light stack on the dash. I was just playing around with the paddle shifters and I hit the (left) - shifter a couple of times and I noticed my number 10 light go out and the truck downshifted, so I did it again and 9 went out, another downshift. This is all being done in drive mode not manual. So i starting playing around more and I guess after starting the engine you can remove all the gears you want in drive mode and it stays that way till you restart truck or add them back with the + shifter. Does this work for others?
NASSTY
ME
Yes, hitting the - button on the console shifter or the - left paddle shifter will lock out gears.
shapiroeric
Longmeadow, MA
Yes a neat little feature....for me I just drive in Sport Mode all the time and the truck is much more enjoyable....2 clicks with my thumb on the Mode up steering wheel button is becoming automatic for me....
AvoidTheBoyd
Wisconsin
My 2015 Lariat did the same thing with the 6 speed tranny using the rocker switch on the shifter. Nice for towing and for holding RPMs downhill, loaded or unloaded.
NO LIMIT
Alberta
You mean that thing in the glove box? That's what that is?
Yours fit in the glove box ???...No matter which way I turn mine I can't get it to fit...about 1/4" to wide to close the glove box.
