Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forum Supporting Vendors > FordRaptorLights.com
BuiltRight Center Dash Mount - Gen2
This is a discussion on BuiltRight Center Dash Mount - Gen2 within the FordRaptorLights.com forums, part of the Ford Raptor Forum Supporting Vendors category!
BuiltRight Industries has done it again with another great accessory for your Raptor! If you're looking to mount a cell ...
Old 02-14-2018, 11:49 AM   #1 (permalink)
FordRaptorLights.com's Avatar
Default BuiltRight Center Dash Mount - Gen2
BuiltRight Industries has done it again with another great accessory for your Raptor! If you're looking to mount a cell phone, GPS, dash cam, radar detector or other accessories, look no further than the new dash mount specifically built for the 2015+ F150 / 2017+ Raptor.
Features:
  • Mount your cell phone, GPS, dash cam and other accessories with ease!
  • Laser cut and CNC formed for perfect fit
  • Durable black textured powder coat
  • Made in the USA
  • Patent Pending
Order Link ---->>> Link to ORDER ----->>>> FORDRAPTORLIGHTS
The BuiltRight Industries Dash Mount provides a rigid, durable mounting point for all types of accessories. With room for multiple mounts, users can attach and configure their devices with infinite adjustability. A popular combination with our product testers was cell phone, radar detector and dash cam, from left to right. The Dash Mount was born from the lack of phone mounts that give you the ability to position your device where you want. 'RAM' brand ball and socket mounts are an excellent addition to the Dash Mount and although we don't yet have them in stock, they are readily available on Amazon. The slots used in the design are sized to accommodate AMPS standard attachments.
Installation is very straight forward. The laser cut and CNC formed bracket attaches to the tray located above the dash using four machine screws, included in the hardware kit. The four .25" holes used must be drilled by the user in the OEM tray. Should you choose to return to stock, the OEM rubber mat inside the tray conceals the holes.
The bracket is manufactured from 12ga mild steel and finished with a durable black texture powdercoat - a very close match to the OEM dash finish. Each kit contains the Dash mount bracket, four machine screws, four washers and four locking nylon nuts. Also included are printed instructions and a BuiltRight sticker!
Jeff
FordRaptorLights.com is offline   Reply With Quote
Old 02-14-2018, 01:10 PM   #2 (permalink)
zombiekiller's Avatar
What are the dimensions of the raised mounting surface?
zombiekiller is offline   Reply With Quote
Old 02-14-2018, 04:22 PM   #3 (permalink)
Top surface area of the shelf is 2" x 6.5"
Jeff
BuiltRight Center Dash Mount FordRaptorLights.com FordRaptorLights.com 24 02-24-2018 09:19 PM
Center dash vibration after Whipple Install Sandman1911 Ford Raptor Problems and Questions Forum 8 01-19-2015 09:13 AM
2014 dash bezel (Center Stack) replacement zer0gravity Ford Raptor Audio/Video/Electronics Forum [GEN 1] 5 12-09-2014 02:16 PM
Center channel dash speaker? Rickoo Ford Raptor Audio/Video/Electronics Forum [GEN 1] 23 04-29-2014 11:56 AM
Center dash speaker trugrit Ford Raptor Audio/Video/Electronics Forum [GEN 1] 11 03-07-2013 11:14 AM
