jblakesmith
I've decided on a 37 12.5 r20 tire, but am now between the Toyo RT and MT. The RT is probably the smarter choice (lighter, mileage warranty, lower price, better on road which is what my Raptor primarily sees), but the deeper tread and end caps of MT are very appealing as well. Just wanted to know your thoughts and if anyone has heard the 37 12.5 r20 MT is hard to find? The 13.50 is plentiful (shown below), but I wonder if the 12.50 is newer, thus more scarce?
I'm also between the Fuel Trophy (anthracite ring) 20 x 9 +20 offset or the KMC XD128 (all black or anthracite with black ring) +18 offset. Does anyone know if the bolts are removable on the ring so if in the future I could remove during ring topcoat? Are both these wheels hub or lug centric? Could I get 0 or +1 offset to work without major trimming on high perch? Or would this stick out too far? If my calculating is correct, a +20/18 offset with a 9 inch wheel will bring stock out almost an inch.
From what I've researched, I should be ok on top perch with minimal trimming and maybe pinch weld hammering. Any comments, opinions, expertise is greatly appreciated as I've been pondering new wheels/tires for a while now.
