CO DUSTORM
Just picked up a 2012 SCREW with 17K miles. It has the stock wheels (machine faced w/black) and tires. Keeping the wheels, what is the largest tire size that can safely fit on these wheels?
Thx in Advance
Thx in Advance
Stock BFG's are actually 34.4". Something like a Toyo or 35x12.5x17 will be a true 35". I wouldn't go any bigger unless you change your mind and do some trimming but ultimately a set of 37's would be the best for it. The BFG 37's are actually like the stock, being at 36.5". They will work if you don't plan on going off-road or make full lock turns. recommendation would be to replace fenders and cut/pound out the pinch weld.
Plenty of threads here on tires, plenty.
