Stripped lug nut?
Floyd91
Has anyone had any experience with a stripped lug nut on their stock wheels. Went to do the mid perch this morning and found that not only am I missing a lug completely, but one of the other lugs looks beat to shit and is stripped.. FML.:flipthebird:
Glassman
Santa Clara
one of the first problems experienced when changing a flat out in the desert, replaced all with spline nuts
F
Floyd91
How'd you get the stripped lug out? I'm thinking I might have to grab a 5/16 chisel and start cutting.
MTUH3
Plymouth, MI
That is what I had to do. Chisel down the "cap" enough to get down the the nut below. Had to be real careful not to damage the tire
Deleted member 12951
Assume wheel. If you had to be careful not to damage tire then you were swinging that hammer like a SOB. lol
MTUH3
Plymouth, MI
LOL..... yeah wheel.
F
Floyd91
That's why I'm letting the rage subside before starting again lol.
FP Forged
Justin
Reno, NV
In the past when taking stripped lugs or locks with out keys off I would find a nice solid socket that is slightly smaller than said lug and and hammer it on. Hammer it on the lug as far as you can. Once the socket is as far as it's gonna go use a breaker bar and go slow. If that doesn't work a reverse threaded socket should do the trick. It's kind of a bitch to get it started though
http://www.summitracing.com/nv/parts/wmr-m980/overview/
