Stock wheels plastidipped and 1.5" wheel spacers
Digger
Oxford, Ma
I didn't prime mine either & I plasti dipped them last fall. This is the 2nd winter on them & there isn't a mark them yet. I'm definitely getting the 1.5" spacers that he has on his black Raptor. That thing looks awesome spaced out like that.
Flaltlander1414
Roseville, CA
Will there be any rubbing with a 1.5" spacer. I have 37's and glass with stock wheels. I need more offset because my wheels rub the liners at full turn. I cant afford new wheels at this time.
Flaltlander1414
Roseville, CA
Nope already beat it to hell. Its rubbing the front side of where the fender outlines the coilover. Heres a pic. bottom left corner when I turn
banman12
banman12
Rochester, NY
I dont have any issues with rubbing. I am at mid perch as well. The spacers basically put the stock wheel where a Method with a 0mm offset would sit. I have not had any rubbing issues with my Methods either.
Flaltlander1414
Roseville, CA
Are you running 37's w/glass fenders and glass liners? Im worried that a 1.5" spacer will rub in the rear at full compression. Methods are a 1.32" offset, so the spacer are a little wider. These 37 general grabbers are pretty wide
Bigg50
Vallejo, CA
You could go with a 1 inch. Might want to do some research on how well spacers hold up offroad. I've heard they can fail but than again I haven't really looked into it.
gallopingford
Leesburg, VA
What is a reliable spacer brand for the 1.5" ones? I've done spacers on many of my vehicles but always invested in quality ones, any ideas for the F150?
