Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford Raptor Wheels & Tires Forum [GEN 1]
Shaking tires? Sandbags to even out?
This is a discussion on Shaking tires? Sandbags to even out? within the Ford Raptor Wheels & Tires Forum [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
Hi all, Just got some method standards and goodyear mtr's installed. Really happy with the look and how quiet the ...
Like Tree1Likes
  • 1 Post By vince7870
Sponsored By: Texas Motorworx
Old 12-29-2014, 07:14 PM   #1 (permalink)
Default Shaking tires? Sandbags to even out?
Hi all,
Just got some method standards and goodyear mtr's installed. Really happy with the look and how quiet the tires are.
Everything was great until I got on the high way. At about 60MPH the truck was shaking all over the place. My initial thought was that they must have miss-balanced my tires right?
I called the guy that did the mount and balance and he said the following:
"The MTRs have sandbags in them and if you drive on it for a little bit the bags will even themselves out and the vibrations will go away."
I am not a tire expert, but this seems wrong.. Any thoughts guys??
raptorwarrior is offline   Reply With Quote
Old 12-29-2014, 08:25 PM   #2 (permalink)
BAJASVT's Avatar
There's a method of balancing tires that uses a media inside the tire such as sand or pellets instead of weights attached to the wheel. The balancing media does not come in the tires, so if it's in your tire assembly it means that it was put there by whoever mounted them on the wheels. It's not unheard of for this method to be used with larger tires, but I've never heard of people having luck with it; I tried it once and it didn't work for me. I would take them back to have the sand removed and have them balanced conventionally. Good luck with those MTRs... I had a set on a truck which turned into multiple sets due to prorated warranty replacement from Goodyear because they kept shaking, wobbling, wouldn't balance, broken belts, etc. and finally sold them dirt cheap on Craigslist with the disclaimer that they were the worst tires I ever owned. This is possibly why your tire shop attempted to balance them with sand.
BAJASVT
BAJASVT is offline   Reply With Quote
Old 12-29-2014, 10:14 PM   #3 (permalink)
vince7870's Avatar
warned you in your original thread. get the sandbags out and have them road forced balanced or a specialty 4x4 shop. mine did the same, they added more beads and then the shake was at 70mph. krazy house cleaned mine out and rebalanced,,,,,they were perfect after that. they just got too noisey. good luck....they balance eventually, and it take a lot of weight.
KaiserM715 likes this.
Lead, Follow or get out of my way!
vince7870 is offline   Reply With Quote
Old 12-29-2014, 10:20 PM   #4 (permalink)
BAJASVT's Avatar
Yes. One of mine had 22oz. of weight and several of them required over a pound.
BAJASVT
Old 12-31-2014, 06:03 PM   #5 (permalink)
whoisbigman's Avatar
I have used "sand bags" on dozens of sets of tires and they work great. I have them in my 37s now. They work best on larger tires because larger tires usually require more weights than smaller tires so unless you want a big hunk of lead on your 49' Iroks, you use media bags. When they first came out, we would put the whole bag, unopened, in the tire. After several miles, the bag would open and disintegrate. But those first few miles would be rough. Now I tear the bags open and just put in the media.
The only problems you should have with the media, if the right amount was installed and the bags were opened, is sometimes when you hit a large bump or rut, it will disrupt the media and your tire will be out of balance momentarily. This would be annoying on woops or off road, but on the street, the tires should ride awesome.
---------- Post added at 06:03 PM ---------- Previous post was at 06:01 PM ----------
The truck in my sig has 20" of lift and 46" Mickey Thompsons with media bags in them. It drives straight, smooth, and has no problems at any speed and I've gone 80 on the highway.
2012 Tux Black, Loaded. Previous owner added Spray-in liner, bed cover, LED everything, AFE intake, Magnaflow Exhaust, mid-perch... other stuff I haven't found yet. Thank You whoever you are... I have added 37" Nitto tires, painted speaker grilles, Roush vacuum gauge for hubs.
whoisbigman is offline   Reply With Quote
Old 01-03-2015, 02:18 PM   #6 (permalink)
Ramrodthrusterpuppy's Avatar
^This.
I've used Dynabeads (and similar product) in all of my off road tire applications for balancing and they work great. However, as stated above, the installing technician has to know what they are doing and the right amount of beads to add to each tire. Too little and they don't spread around the tire enough to balance...too much and the excess will collect and throw off balance at speed. I will never use clamp/stick on weights again for large diameter tires.
Ramrodthrusterpuppy is offline   Reply With Quote
Tags
balance, goodyear, mtr, shaking, tires
Time to upgrade wheels and tires.. Need help on tires.. hoxman Ford Raptor Wheels & Tires Forum [GEN 1] 14 07-02-2014 04:33 PM
WTB TIRES or Tires/Wheels in MIAMI area ASAP SilentShooter Want to Buy 4 06-19-2014 11:23 AM
Two BFG OE tires FS CAbimmer Garage Sale 2 06-12-2013 11:39 PM
Looking for new tires Timothy T Ford Raptor Wheels & Tires Forum [GEN 1] 4 03-15-2012 03:05 PM
