New wheels and alignment question
RV67
Corrupt Illinois
Hey all -
Last nite I ordered new bfg's and method DBL standards.
Today I went to a reputable shop to make appt. for front end alignment and one of the guys working there said that if the new wheels have a different offset it may change the alignment ......huh ? He says you may want to do alignment with new wheels instead.
I know folks change wheels often and I have never heard this.And I ordered the dbl standards 17 x 8.5 -6 x 135mm 0 offset / 4.75 back spacing.
I could see if I was going to 20''s but Im not too far from stock.Can someone who knows alignments shed some light on this ?
******Also Can I use factory lugnuts on method wheels ??******
Thanks
FP Forged
Justin Lundy
Reno, NV
Hey all -
Thanks
I never re-aligned with my methods. If you're coming from warn tires (50% tread or less) and putting new tires on it's good to align after you get new ones. If not I wouldn't worry about whether it's done before of after.
You cannot use stock lugs. You will need aftermarket.
BAJA1K
Do alignment with new wheels and tires mounted. Method wheels need a small diameter lug nut. Stock lug nuts will not work. I have a set of used small diameter black Gorilla spline lug nuts for sale $50.00 includes spline key as well. Free shipping to you if you want them.
RV67
RV67
Corrupt Illinois
Pics and how used are they ? Where are you shipping from ? Send me a PM please and Thanks
Also Thanks for the quick replys from all I just did a search and finally found someone who also said No on the lugs.
BAJA1K
Lug nuts
Here are the pics of the lug nuts you need.
