New tires floaty with no "feel"
Metaman
Los Angeles
Hey all,
I installed a set of new Yokohama Geolander AT-S tires to replace my worn stock KO's on my 2013 Raptor SCAB – standard size 315/70 R17.
On the street they feel incredibly floaty with little "feel" compared to the KO's.
In corners the lack of feel has me over-compensating with oversteer and generally I have little confidence going into a corner at a higher speed now.
Anyone have any similar issues? Could this be due to the lack of kevlar sidewalls making the tire flex more in the corners?
I have tried different air pressures too – 40, 44, 48. All pretty much the same.
Thanks for any feedback!
WRCRaptor
Great Lakes
2 things to consider.
New tires can feel that way because the have more tread and squirm a little more the lower tread depth older tires.
Also new tires need to break in i.e. wear off the mold release agent. 300-500 miles
I have no experience with that tire so not much help for you on sidewall difference.
infinitereality
SLC IR/8
Louisiana
I had a similar issue no long after putting new tires on. Mine kind of scared me when going over bumps at higher speeds. I ended up having a front shock that was leaking, put 2 basically new take offs on and problem was solved.
