Need help with Fuel Trophy size
boosting1bar
Melbourne, FL
I'm going to order a set of Fuel Trophy's today (hopefully) to use with my stock tires and I'm trying to retain as close as possible to stock stance (don't want to deal with rubbing, etc). I have the faux beadlock wheels from Ford on my truck currently and I think the Trophys I want are the D55217858345 but I've looked at so many different wheels and part numbers and offsets and backspaces the past 2 days I've completely confused myself lol! If one of you guys could help a little I'd really appreciate it.
Double Tap
Nashville, TN
You want the 17x8, 6x135 bolt pattern and "6" offset. My D551's were the #D55117858950 wheel. You want the D552 version of that.
boosting1bar
boosting1bar
Melbourne, FL
marioec
South Florida
17" Fuel trophy's on stock tire
tem specifics:
Manufacturer Part Number:
D55117858950
Rim Width: 8.5 Surface Finish: Matte Black/Anthracite
Bolt Pattern: 6x135 Warranty: Yes
Offset: +6mm Brand:
Fuel
Backspacing: 5" Style: Trophy
Finish: Matte Black/Anthracite Rim Diameter: 17
Hub Bore: 87.1mm Size: 17x8.5
str8fast
Rio Linda
I have those exact wheels and 35" toyos mt I made pretty bad contact on my driver fender cracked in two spots and shoved up about 3/4" so yah they rub hahaha knocked both fender liners out as well . I was running pretty hard at the dunes and most the damage was done when I overcleared my landing and bottomed front and rear suspension. Out.
---------- Post added at 02:58 PM ---------- Previous post was at 02:57 PM ----------
Oh yah and I'm on top perch
