Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford Raptor Wheels & Tires Forum [GEN 1]
KMC Enduro Beadlock Bolts
This is a discussion on KMC Enduro Beadlock Bolts within the Ford Raptor Wheels & Tires Forum [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
Howdy - I have the KMC Enduro wheels on my Raptor. The wheels came with Grade 8 bolts to attach ...
Sponsored By: Texas Motorworx
Old 06-05-2012, 11:04 AM   #1 (permalink)
Default KMC Enduro Beadlock Bolts
Howdy -
I have the KMC Enduro wheels on my Raptor. The wheels came with Grade 8 bolts to attach the beadlock to the wheel. Can I replace the the Grade 8 bolts with stainless bolts? Stainless bolts are not as strong as Grade 8, but I am thinking the threads in the aluminum wheel are the weak link.
Thanks
tnsbruce is offline   Reply With Quote
Old 06-05-2012, 12:58 PM   #2 (permalink)
AngryBird's Avatar
No! Hell No! The threads are not the weak link or they wouldn't spec Grade 8 Bolts. You can do the thread failure calcs if you want to prove this to yourself. You will not be able to achieve the necessary pre-load on the bolts to hold the lock ring on under pressure. This could lead to failure under pressure and consequently severe injury and/or death.
2014 SCREW Mid-Perch, Retrax, Rigid Fogs, Xmitter Prime Xtreme 21", Line-X Spray in Liner
AngryBird is offline   Reply With Quote
Old 06-05-2012, 01:16 PM   #3 (permalink)
vanilla_gorilla's Avatar
Can I ask why you want to swap put the provided bolts?
vanilla_gorilla is offline   Reply With Quote
Old 06-05-2012, 01:43 PM   #4 (permalink)
Glad I asked! Grade 8 will stay. I was getting some corrosion on the bolt heads. I will clean off and stick with the Grade 8 bolts.
I will do some research on the thread failure calculations - it will be an interesting exercise.
Thanks!
Old 06-05-2012, 01:58 PM   #5 (permalink)
And if you are getting corrosion, i would suggest after you clean them, powder coat them to protect them.
Old 06-05-2012, 02:05 PM   #6 (permalink)
Raptorguy21's Avatar
The Bob Vila of Trucks
Originally Posted by tnsbruce View Post
Howdy -
Thanks
Have you stripped some of the threads on the wheel?
2008 F250 "stock-ish".....
Raptorguy21 is offline   Reply With Quote
Old 06-05-2012, 02:50 PM   #7 (permalink)
Check out this link for more info. The Tensile strength is what should be of most interest to you. Also note that there is no Proof Load testing for the stainless.
Bolt Depot - Bolt Grade Markings and Strength Chart
kendasf is offline   Reply With Quote
Old 06-05-2012, 03:36 PM   #8 (permalink)
The shop that mounted the tires stripped a couple - I used helicoil to repair. Ideally, I think these wells should come with helicoils standard for a more secure mounting of beadlock ring.
Old 06-05-2012, 03:56 PM   #9 (permalink)
WSI's Avatar
WSI
You can try clear coating the bolt heads. That's what i do when I want to keep the grade 8 finish.
WSI is offline   Reply With Quote
Old 06-05-2012, 04:11 PM   #10 (permalink)
treypal's Avatar
Lord of the Raptors
Beadlocks strip out, back out and break bolts all the time. I seriously don't suggest them.
treypal is offline   Reply With Quote
Stainless Works Header Bolts dolfanatic1399 Ford Raptor Engine Discussion and Performance Mods-6.2 Liter V8 [GEN 1] 33 03-28-2015 10:34 AM
KMC Enduro Beadlocks Steele16 Ford Raptor Wheels & Tires Forum [GEN 1] 13 05-17-2012 11:44 AM
New OMF Beadlock Simulators DynoDynge Ford Raptor Wheels & Tires Forum [GEN 1] 14 03-25-2012 10:27 PM
Nuts and bolts CAbimmer Ford SVT Raptor General Discussions [GEN 1] 4 02-13-2012 05:04 PM
Nuts & Bolts Inspection? SVTRay Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 12 10-09-2010 12:38 AM
