KMC Enduro Beadlock Bolts
tnsbruce
Howdy -
I have the KMC Enduro wheels on my Raptor. The wheels came with Grade 8 bolts to attach the beadlock to the wheel. Can I replace the the Grade 8 bolts with stainless bolts? Stainless bolts are not as strong as Grade 8, but I am thinking the threads in the aluminum wheel are the weak link.
Thanks
AngryBird
Near Santa Fe, NM
No! Hell No! The threads are not the weak link or they wouldn't spec Grade 8 Bolts. You can do the thread failure calcs if you want to prove this to yourself. You will not be able to achieve the necessary pre-load on the bolts to hold the lock ring on under pressure. This could lead to failure under pressure and consequently severe injury and/or death.
T
tnsbruce
Glad I asked! Grade 8 will stay. I was getting some corrosion on the bolt heads. I will clean off and stick with the Grade 8 bolts.
I will do some research on the thread failure calculations - it will be an interesting exercise.
Thanks!
Raptorguy21
The Bob Vila of Trucks
Hell Paso
Howdy -
Thanks
Have you stripped some of the threads on the wheel?
T
tnsbruce
The shop that mounted the tires stripped a couple - I used helicoil to repair. Ideally, I think these wells should come with helicoils standard for a more secure mounting of beadlock ring.
Allied Offroad
Kansas City
You can try clear coating the bolt heads. That's what i do when I want to keep the grade 8 finish.
treypal
Lord of the Raptors
Riviera TX
Beadlocks strip out, back out and break bolts all the time. I seriously don't suggest them.
