Best 37s on top perch
jblakesmith
Bonaire, GA
Also this is just a quick tip and mod that is easily done.
on the lower control arms there is a little nub that acts as a stop that reduces the amount of degrees you can turn. by taking an angle grinder to that nub and grinding it down to your desired height it freed up the turning radius especcaily with 37's
Thanks again. About to pull trigger on Toyo MT 37 12.50 20. Already on top perch. Going with Fuel d551 trophy in 20 x 9. I'm torn between +20 or +1 offset. I know the +20 will be better for fitment (not as much or no trimming), but I'm concerned I may regret not getting the +1. What offset wheel width did you run with your nitto 37 x 12.50? Thanks.
