Beadlock Screws
mvasilakis
I just bought a 2013 Raptor that came with factory beadlock wheels. The hex screws that hold the trim ring are badly oxidized and several look to be either rusting or oxidizing orange behind the screw.
Does anyone know where I can buy replacement hex screws for the trim ring?
Also is there something anyone recommends that I coat the screws with to prevent oxidizing and by extension galvanic corrosion in the future? (Which is what I am assuming I am seeing if it's not simple rust.)
Thanks for any assistance.
Mano
Houston Raptor
I'm in the same boat. I'm wanting to replace almost all mine. Wondering if I can just change to a different screws. These are just starting to look horrible.
M
mvasilakis
Thanks for the parts link. At 5.50 each it's going to get expensive. Pretty much all of them are shot. Even the few that show no signs of rust yet are oxidized pretty bad. The Amsoil idea will probably work till I get around to dealing with it the proper way.
The only real long term options are to buy new ones or remove the old ones, treat the rust buildup with a rust remover, and paint with an epoxy spray paint. Like DuraCoat or Aluma Hyde II.
Thanks for the responses.
Trick.Raptor
The Cracker Raptor
Santa Maria, CA
How many are you needing?
This is the part:
LOCK RING RETAINER SCREW - Ford F-150 Part # W716548S450B
Can google that or go to tascaparts.com
LOCK RING RETAINER SCREW for 2014 Ford F-150|-W716548-S450B
Reviving this old thread figuring if anyone would know Rick would :)
Do you know if these ring screws can be purchased outside of Ford etc? Is there like a screw outlet where you can purchase the same screw for less?
Having to spend $63 per wheel for screws seems excessive.
Deleted member 12951
I made some clever deals and ended up getting a whole set of screws (48), so I am set. I did give a few away to help someone in need. I have not had an issue with mine except when offroading and shaved off the heads of a few. Damn ruts!!
Trick.Raptor
The Cracker Raptor
Santa Maria, CA
I made some cleaver deals and ended up getting a whole set of screws (48), so I am set. I did give a few away to help someone in need. I have not had an issue with mine except when offroading and shaved off the heads of a few. Damn ruts!!
I've found them being sold for $3.10 but I will hold out to make a deal like you... I want new ones to go along with rings that don't go off-road for street queen duty.
One set for off-road... one set for on-road.
