Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford Raptor Wheels & Tires Forum [GEN 1]
Any 35's that won't fit at low perch?
This is a discussion on Any 35's that won't fit at low perch? within the Ford Raptor Wheels & Tires Forum [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
Hi all, I know that there are probably several hundred threads on this...but I had difficulty finding an answer to ...
Sponsored By: Texas Motorworx
Old 10-27-2014, 06:28 PM   #1 (permalink)
Default Any 35's that won't fit at low perch?
Hi all,
I know that there are probably several hundred threads on this...but I had difficulty finding an answer to my question specifically...
Do all 35x12.5x17 tires fit without ANY rubbing on the stock wheels at low perch? It seems that maybe some people had problems with Toyo M/Ts fitting correctly without some trimming..
Thanks
raptorwarrior is offline   Reply With Quote
Old 10-28-2014, 08:11 PM   #2 (permalink)
SDHQJASON's Avatar
Typically you will need to go to the Mid-Perch setting to clear a true 35x12.50R17 tire.
SDHQJASON is offline   Reply With Quote
Tags
35s, fit, raptor, rubbing, tires
From mid perch to top perch, not going back to mid perch canamds450 Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 16 01-11-2016 08:50 AM
Top Perch to Mid Perch 2014 BuckshotX5 Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 16 05-06-2014 04:57 PM
Mid Perch Mod - Need Help Please pjaus2002 Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 34 04-14-2014 12:08 AM
Mid Perch Mod- is it done? apeezie289 Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 4 04-13-2014 09:16 AM
Low perch to top perch to mid perch in 18 hours worduck Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 28 12-18-2013 04:11 PM
