Recently received Method NV Wheels for my Ford F-150. Was immediately disappointed with the look and quality of the center cap. I looked into the billet caps vince7870 makes but these would not work for my bore or wheel thickness. I then got the idea of adapting the method roost center cap to the NV. Turns out this was very simple.
I went to Methods webpage, into their parts list and ordered the roost center cap that matched my wheel lug, spacing and center bore. The caps came with the 5M x.08 bolts and even a wrench. Cost was $140 shipped.
Installation was pretty simple just layout drill and tap. This took 20-30 minutes a wheel.
The roost cap will work on other Ethod wheels where the face is flat around the lug holes. Mesh for sure, I didn't look at the other styles close enough.
NV cap provided
[/url]print screen[/IMG]
Roost cap layout
[/url]post a picture[/IMG]
Pilot drilled
Threads tapped
Cap installed
Wheel bolted up
NV cap provided
Roost cap layout
Pilot drilled
Threads tapped
Cap installed
Wheel bolted up
