Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford Raptor Wheels & Tires Forum [GEN 1]
39-40in tires
This is a discussion on 39-40in tires within the Ford Raptor Wheels & Tires Forum [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
Like Tree6Likes
Sponsored By: Texas Motorworx
Old 01-04-2018, 11:21 AM   #1 (permalink)
Junior Member
Default 39-40in tires
I have a 2013 raptor with fox 3.0s front/back.
Iím running 37in BFG tires right now, no fiberglass and they work fine.
I purchased the +4 2in fiberglass and want to get bigger tires. Donít plan on getting any long travel system right now. I want to run a 39 or 40in tire. Iíve looked up answers but canít seem to find anybody actually doing it. What do I need to do to make it work. Mainly because I like the look, but also want it to function off road as it does now.
Please let me know how to go about this
timbo33 is offline   Reply With Quote
Old 01-04-2018, 11:38 AM   #2 (permalink)
Aaron's Avatar
Meme Corps Commandant
39's can be done. Walter Burch and Donnie Steele on Facebook have done it. I'd assume to run hard you're going to need to do some firewall trimming which isn't going to be the most fun.
Edit to add. Your Power steering will not thank you for doing this mod.
John813 likes this.
COMMANDANT OF THE MEME CORPS
MCLTW!
It is not who we are that matters....what matters is our memes...
Aaron is offline   Reply With Quote
Old 01-04-2018, 03:48 PM   #3 (permalink)
Junior Member
Ok! Do you know if they are running the stock suspension setup? Or more advanced long travel?
As of now I wouldnt be doing any upgrades suspension wise, but would like to use the bigger tires.
Old 01-04-2018, 04:30 PM   #4 (permalink)
Aaron's Avatar
Walters was on 3.0s AFAIK, Steele is on some other advanced shit.
If you really are intent on trying this, Look for some used ones you can mount and try out. It'll be REAL apparent where trimming and rubbing is taking place.
Also, like I said, your steering rack is NOT going to like you.
Truckzor likes this.
MCLTW!
Old 01-04-2018, 04:35 PM   #5 (permalink)
Junior Member
Ok thanks!
I have the Howe power steering system from RPG. But the steering rack is stock, but that makes sense now that you mentioned it
Old 01-04-2018, 04:41 PM   #6 (permalink)
Doc Constantine's Avatar
I think Walter has the Icon setup and Donnie has SVC, probably podium package.
Aaron and Steele16 like this.
Doc Constantine is offline   Reply With Quote
Old 01-04-2018, 04:44 PM   #7 (permalink)
SVT_Aaron's Avatar
I am currently running 37" BFG Baja T/A and had to trim/ bend pinch welds on the firewall. which will soon turn into cutting into and push back the firewall and fabricate then weld a plate onto it after. with that being said if you are trying to go 39/40 then you will have to modify for sure. I am running KING 3.0, SVC UCA's, & tie rods, when off-roading and turning sharp the tire is rubbing pretty gnarly against the firewall. the only other time that it rubs is when in reverse and turning sharp. I do know that Donnie Steele is running somewhat the same setup, but his setup is more advanced and running 39"
I like to go fast...
SVT_Aaron is offline   Reply With Quote
Old 01-04-2018, 09:53 PM   #8 (permalink)
Steele16's Avatar
Mines Podium and I roll the lower all the way ahead with the adjustments before i welded it up. Firewall will need to be moved for clearance at compression though.
Aaron likes this.
Originally Posted by sabumaru View Post
As a europeaan the amarican offroad scene is new to me
But i like the way you people do things
Steele16 is offline   Reply With Quote
Old 01-13-2018, 05:36 PM   #9 (permalink)
tplee's Avatar
What wheel backspacing are you running? Will make a world of difference.
Sent from my Pixel using Tapatalk
-Tommy
2014 SE SCREW | 37" BFG MT/KM2's on ONE Bead locks
tplee is offline   Reply With Quote
Old 01-17-2018, 05:40 PM   #10 (permalink)
SVT_Aaron's Avatar
sorry for late response, backspacing is 4.75
40in Rigid led bar Perauto Garage Sale 3 03-11-2018 12:05 PM
New 2017 Ford Raptor Video Touts New BFGoodrich Tires KO2 Tires MyRaptorArk Ford F-150 Raptor General Discussions [GEN 2] 8 07-15-2016 11:56 AM
WTB TIRES or Tires/Wheels in MIAMI area ASAP SilentShooter Want to Buy 4 06-19-2014 11:23 AM
