37's on wifes new supercrew
RallyeX
We bought a 2014 Supercrew last weekend for her. She wants to run the Toyo M/T Open Countrys 37x13.5/17 on stock Raptor bead lock wheels and shocks on middle perch. Also will roll the lip inside the fender wells front and rear. Will this be ok? Any rubbing issues?
She also ordered front and rear bumpers from RPG. Also on order AMP electric side steps, 40" light bar and 2 3x3 led pods.
Thanks
Here is my 2013. Also have bumpers on order and going with 37" General Grabbers.
And here is our serious Ultra4 build. This is at full bump. Building a LS1 383 stroker motor.
Key
Abilene, TX
Will she be taking it offroad? Compression of front shocks can and will destroy the wheel well if you're running 37's on stock suspension.
---------- Post added at 10:32 PM ---------- Previous post was at 10:31 PM ----------
Ps, her truck looks great!
2014RubyRed
Galesburg, IL
First of - your wife is super cool!!! Wish mine was as enthusiastic about wanting her own rig. Second - you look like your not scarred to do some work - get some new fenders and give her the big tires she wants. Feed the need!!!!
Bulletnjm
New Jersey
Wow that's awesome! If you don't plan on off-roading it you will be fine on mid perch and hammered pinch welds. Although you may get slight rubbing at full lock. @BearLeeAsian can chime in maybe
BearLeeAsian
Dallas Texas
I have the same exact tires on my truck except they are 20s.
I had rubbing issues at full crank as @Bulletnjm suggested. But my pinch welds were not hammered in. You could pull off your fender / fender liner and hammer it in and see what happens.
A member on here ran 37 BFG with no issues (no off roading). It's because the BFG was a 12.5" tire vs toyos 13.5".
Jordan@Apollo-Optics
aka <b><font color='darkorange'>LSUstang05</font><
I have 37's on stock suspension with just mid perch. The key is getting aftermarket fenders and beating the pinch weld down. Otherwise you'll shred tires. With stock offset you may be able to get away with stock fenders if you don't offroad.
R
RallyeX
Thanks for the responses. Her truck won't see much dirt. Mainly towing the Jeep to the trails.
Jeff
DezertRacer
Las Vegas,NV
Jeff
12.50 on a stock beadlock wheel i wouldn't see a problem at all, but with the 13.5 Toyo it actually measures out to like a 14.40 on a 10" rim .. so on the factory wheel i think it would still be close to 14. I run a 37/12.50/17 on factory beadlocks and have hammered pinch welds . No issues at all Just be careful at full lock
