37" Tires - Nitto Grappler vs. Toyo Open Country M/T
What do you guys think about Nitto Grapplers vs. Toyo Open Country M/T? Are the Grapplers much louder on the highway than the Toyos? Any other thoughts on the tires would be much appreciated. As you can tell by my handle, I'm a rookie.
Have a 2014 Raptor, going with Method NVs and putting Boatec fenders / liners and going to mid perch.
Thanks!
Jay9722
ATL
Which Grapplers are you thinking...trail, terra, or mud? I have 35 Trail Grapplers on OEM beadlocks and they are considerably louder than the stock BFG's. I had Goodyear Duratracs on my Toyota and those were about as loud as the Nitto. I can't speak for the Toyo's. FWIW the Goodyears and the Nitto's are great tires so far. They balanced perfectly the first time and I've had zero problems thus far. The Nitto seems to have a larger footprint and appears to be more square compared to the Goodyear which appears more rounded(if that makes sense). I will buy the Nitto's again.
charles06
Windermere, FL
Toyo produces the Nitto brand as a lesser expensive tire (in most cases), so by default, the Toyo's are a little bit better quality. I've had 40" Toyo's on a previous build, and the ride quality was great.
truckarl
I would recommend the Trail Grappler. It's not MT but can perform well in the mud and wers well.
