Darthyota
so what all do i need to do other then mid perch? I've got the fiberwerx 2.5" fenders do i still need to massage the pinch weld?
Off topic... how have you liked your Duratracs?
Back on topic, sort of... would you have stuck with Duratracs if they came in a 37"?
Really back on topic... who's had a stock wheel rubbing issue with a 37" tire on the upper control arm?
Also, post pics of new red label 37" tires not mounted to make thread more interesting!
how thick are the spacers? i had them just toss my duratracs back on for now as when i tried to do the mid perch in the driveway yesterday i quickly discovered that my drivers side coilover lower perch is seized into place
I imagine a 13.50 would rub on UCA... My 37-12.50's rubbed through the hub vacuum lines that run on the outside of the UCA and spindles. Had to re-reoute them.
