37" Bfg,Methods,Mid perch
RaptorFlipper
The Woodlands, Tx
So some clarification on the mpg. I have had the 37's for about 8 month's and my average mpg has dropped .2 over the entire course of the vehicles history(close to 30k in miles). So more accurately it is probably .3, .4 mpg. I don't give a shit about mileage like couple of you guys said, and I didn't buy this truck to worry about fuel economy. I drive pretty hard, so I do not think the mpg was affected that much. Lekrap is right there is a slight loss in acceleration, but I am talking slight. BUT, I have every bolt on/tune/air enhancement possible on my truck. 565 hp at the rear wheel, so an NA raptor, or less modified one might see a bigger decrease in the acceleration. Wouldn't know, did all the engine mods first, then the tires.
Bulletnjm
New Jersey
Putting 565 hp to the wheels is certainly incredible for a stock drivetrain. I am curious to see how well the stock drivetrain will hold up. I assume you must drive it hard all the time? Do you have anything for the transmission?
RaptorFlipper
The Woodlands, Tx
Good point Bullet! I do drive fairly hard all the time. I am going to upgrade the driveshaft next month. You can see skylar's thread on here where she snapped her drivetrain when she jumped on her sc raptor a few years a go. My tech is super knowledgable and really only works on race cars and my truck, so I am just doing what he says. No problems so far. What were thinking on the transmission? Upgraded billet pump? I have thought about changing the gears, but it is expensive, and really how much faster can or do I need to go?
LekRap
Corona, CA
Thanks @RaptorFlipper for the further explaining the MPG's and acceleration. I definitely wasn't trying to be a **** or "call anyone out" or anything like that. Just was trying to clarify some things that I had heard about 37's from friends. I also had 37's very quickly on my truck (had an old set that I slapped on some extra wheels). I didn't recalibrate the computer for the adjusted rev's per mile, so my onboard computer was way off. The consensus from guys I've talked to about it was about a loss of 2 MPG's from 37's (even lighter 37's like BFG all terrains). That would make sense to me since the truck has to work harder on acceleration to spin a larger diameter tire.
I've always been very impressed with how well the raptors handle stock 35ish sized tires. I personally feel like 37's push it over the edge slightly (on a relatively stock/ NA motor). But I will have to admit that 37's look bad ass on raptors. I think the supercharger makes that basically a non issue to you RaptorFlipper. Guess it's just a personal preference thing. I still go back and forth, but I actually still have time to think as I am only about 1/2 way through my stock 315's.
RaptorFlipper
The Woodlands, Tx
Wow! I can tell you it is not 2 mpg loss. At least not for me. That is a lot. Strange how people get different mpg's everywhere. Anyway, the 37's really look good, but I would assume with no sc, you would see a drop in acceleration for sure. I just like how they fill out the well more. And bfg's are not true 37's either. More like 36's really. I think the exact measurement is around 36.2. Otherwise there would be rubbing for sure.
CAraptor
Yes
---------- Post added at 06:16 PM ---------- Previous post was at 06:12 PM ----------
I have whippel super charger and 37s but I drive it hard and get 8.5 mpg. I was getting 10 before 37 and supercharger but accelerating much slower. Lol
B
BAJA1K
FYI Bfg 37x12.5x17 AT weighs 71.3 lbs. General grabber 35x12.5x17 weigh 77 lbs. So just because some tires are 37" does not mean they are heavier.
LekRap
Corona, CA
I realize that weight is a big factor, but isn't overall circumference also a contributing factor? No matter what the weight, the truck still have to spin a larger diameter tire. That has to take more effort, right?
B
BAJA1K
My opinion is that if the weight is lighter the only possible issue is the tire clearing the fenders and turning radius. I do not think it takes any more effort to spin a lighter tire just because its bigger. I think someone with physics knowledge can tell us.
---------- Post added at 08:49 PM ---------- Previous post was at 08:31 PM ----------
Looks like there is thread already called unsprung weight vs. rotating mass. Very interesting write up.
Truckzor
Swapping to larger diameter tires is the same thing as swapping to a higher gear ratio, which requires more power to move the truck, as the engine has less leverage.
