Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford Raptor Wheels & Tires Forum [GEN 1]
20 x 12 " Wheels Advice
This is a discussion on 20 x 12 " Wheels Advice within the Ford Raptor Wheels & Tires Forum [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
Originally Posted by Ramsel1800 The level kit is fine. If you say so. Hell what do I know. Your truck ...
Like Tree12Likes
Sponsored By: Texas Motorworx
Old 06-21-2013, 12:32 PM   #11 (permalink)
Sliver Raptor's Avatar
If you say so. Hell what do I know. Your truck your money.
Back to the original question though, I think you are going way to wide of a tire for the truck without adding fiberglass fenders.
Sliver Raptor is offline   Reply With Quote
Old 06-21-2013, 12:32 PM   #12 (permalink)
Bigg50's Avatar
You might want to consider only pushing the width to 10 inches. Most have run into rubbing issues with wheels that goes past a 0mm offset. Now I'm absolutely positive a 12" wide wheel will be in the negative offset. Also, a 0 offset on a 12 inch wide wheel is not the same as on a 9 inch wide wheel so keep that in mind even if the fuel's are a 0mm wheel.
Ok, I just checked out the specs and it looks like the offset is a rediclous -44. I would say these do not work and fuel might have just had them on a Raptor for photos.
http://www.mhtwheels.com/cms_pdf/D256-257%20Driller.pdf
Expedition X Off-Road Team Member
website:www.expeditionxoffroad.com
facebook: www.facebook.com/expeditionxoffroad
build thread: http://tinyurl.com/nuh952x
instagram: @expeditionxoffroad
Bigg50 is offline   Reply With Quote
Old 06-21-2013, 01:12 PM   #13 (permalink)
KaiserM715's Avatar
Kaiser Söze
For a street queen, sure. For someone who uses it off-road, not so much.
Take a look at this thread:
This is why spacers are a bad idea. (And lots of cv axle innards pics)
Sliver Raptor likes this.
'10 Raptor - My build
'08 G8 GT
- sold
'04 MazdaSpeed Miata
'67 Jeep Kaiser M715 - sold
Join the Blue Ribbon Coalition . . . it's YOUR Public Land!
KaiserM715 is offline   Reply With Quote
Old 06-21-2013, 01:59 PM   #14 (permalink)
Junior Member
If you go mid perch you loose ride comfort. The leveling block allows you to keep the balance for driving.
i will be using as my daily as well as off road.
But thanks!
---------- Post added at 11:59 AM ---------- Previous post was at 11:54 AM ----------
I thought that might be the case.
thanks for the info.
Ramsel1800 is offline   Reply With Quote
Old 06-21-2013, 03:18 PM   #15 (permalink)
Banned
Lol mid perch vs leveling kit? Shoot me now
Netix is offline   Reply With Quote
Old 06-22-2013, 01:56 AM   #16 (permalink)
TMX Engineer's Avatar
But thanks!
Mid perch you gain ride comfort. The truck was designed at mid perch level but had to be changed due to DOT standards to be able to be sold.... the leveling kit hurts yours trucks ability to be a raptor. Should have just got a platinum for the same money.
12" wheel.... full lock you will contact the fire wall unless you have a pretty good offset... try to stick with 10'' its a safer bet and I will save you some body plastic
We are trying to help you, some are bigger asses and are less tolerant of "lack of tribal knowledge".... but just sit back and listen to the advice because this advice comes from a bad decision or screw up from 1st or 2nd hand experience.
KaiserM715 likes this.
Follow us on INSTAGRAM
Follow us on FACEBOOK
214-785-6568
TMX Engineer is offline   Reply With Quote
Old 06-22-2013, 02:01 AM   #17 (permalink)
Westside Offroad Group's Avatar
yesss a brotruck
Westside Offroad Group is offline   Reply With Quote
Old 06-22-2013, 02:52 AM   #18 (permalink)
Uhhhhhh?!
Marcs is offline   Reply With Quote
Old 06-22-2013, 06:02 AM   #19 (permalink)
BIRDMAN's Avatar
Administrator
We aren't trying to bash you. If you look around there have been a couple documented issues using the leveling kit. It will take some mileage to see the problems but just keep it in mind.
Help Support FRF - Become A FRF Supporting Member!
Get Your FRF Decals
Play slow pitch softball? Check out Softball Forum!
BIRDMAN is offline   Reply With Quote
Old 06-23-2013, 01:58 PM   #20 (permalink)
Squatting Dog's Avatar
Any greater than -6mm offset and you will have issues in the long run. I am saying this from personal (expensive, not covered under warranty) experience (17x10 -12mm)..
Just like top perch (leveling kit) once the front is lifted above 26.5" (measured from center of wheel to fender lip) on 2012+up. You will have issues with tearing cv boots and cv shaft binding (again not covered under warranty).
Another thing to consider is the Raptor suspension is designed to work with the tires sidewall flex. This is the reason Ford/SVT went with 17" wheels, once you plus size your wheels. You have to run a smaller sidewall size on your tires which increases the harshness of the suspension.
-Greg (aka squatting dog)
Squatting Dog is offline   Reply With Quote
Tags
raptor, tires, wheels
Advice on cleaning Method wheels LONGISLANDRAPTOR Ford Raptor Cleaning and Detailing Forum 17 08-23-2014 12:24 PM
SoCal WTT: 2013-14 Ford OEM bead lockable wheels for 2012+ standard wheels Westside Offroad Group Garage Sale 2 07-25-2014 03:13 PM
WTB Method race wheels, or Walker evans wheels & baja ta tires Havasukid41 Want to Buy 1 05-06-2014 04:50 PM
Swapping 2010 wheels with 2013 wheels (stock) Kurfer Ford Raptor Wheels & Tires Forum [GEN 1] 3 10-25-2013 01:44 PM
Advice on Wheels for Excursion (Flame On?) chrison600 Ford Raptor Wheels & Tires Forum [GEN 1] 2 05-01-2013 10:48 PM
