-12 offset? doable?
banman12
Rochester, NY
So what is the main issue with the negative offsets? The fact that you need to be at top perch not to rub, and that is whats causing the increased stress on the cv axles? Like I said, I will not be doing a lot of offroading, but I sure don't want to lose the ability to. If I go with the 17x9 0mm offset (5.00" backspacing), at mid perch, am I looking at any possible issues down the road?
