The 2016 SnoBall Raffle Wish List
Palerider
Pelican 1750 Long Case
MSRP: $225.00
Interior Dimensions:
50.50" x 13.50" x 5.25" (128.2 x 34.3 x 13.3 cm)
•Watertight, crushproof, and dust proof
•Easy open Double Throw latches
•Open cell core with solid wall design - strong, light weight
•O-ring seal
•Automatic Pressure Equalization Valve
•Fold down handles
•Strong polyurethane wheels with stainless steel bearings
•Stainless steel hardware and padlock protectors
•3-piece foam set
Aero precision M4E1 Complete Upper chambered in 300 AAC Blackout with keymod free floating handguard
MSRP: $685.00
M4E1 Upper Features:
•Forged from 7075 T6 aluminum
•Precision machined to M4E1 specs
•M4 feedramps
•Matte black hard coat anodized Mil 8625 Type 3 Class 2
•Laser engraved T-marks
•Comes assembled, with port door and forward assist installed
•Accepts standard AR15/M16 components
Enhanced Handguard Features:
•1pc free float design
•Rail is Machined from 6061-T6 Aluminum
•Built in Anti-Rotation tabs
•Scalloped rails
•Continuous top rail
•1.8" inside diameter fits most muzzle devices and 1.5" suppressors
Barrel Features:
•Chamber: .300 Blackout
•Length: 16"
•Material: 4150 Chome Moly Vanadium
•Finish: QPQ Corrosion Resistant Finish
•Gas System Length: Pistol
•Gas Block Journal: .750"
•Twist Rate: 1:7 Inches
•Muzzle: 5/8x24 Threaded
•Weight: 29oz
•Other; M4 Feed Ramp Extension, HP and MPI Tested, Standard A2 Flash Hider
This guy knows what's up. I tell ya what, I'll give you my brand new Pelican case if you give me a Daniel Defense upper in .300 blk.
