Transmission Oil Filter
ThatGuy88
Quakertown, Pennsylvania
So real quick cause Im on the clock. But gonna be slapping on an AFE tranny pan and want to change the filter while im in there. Its a 2010 6.2 and saw their were a few options for a strainer filter and also a regular pan filter. Are there two filters for these pigs or just one? Thanks in advance for the help guys
Ruger
Northern Nevada
Be careful with the refill. There is a definite procedure for the cold and hot checks. If you don't do it right you'll pump expensive new transmission fluid out on the floor, and whether you do it right or not you're at least 98 percent certain to burn your knuckles on the exhaust.
Dane
Littleton, CO
I realize it was years ago, but did you end up doing this? My specific question is about the filter - I know there are problems with the pickup extension that AFE provides. Did you have issues or did the filter listed in this thread fit the AFE extension?
