Just went through a spark plug change and thought there could be more information on the process like tips and tools. Maybe I missed a couple threads on the forum but the more threads the merrier in this case.
Get these:
Wobble Extensions
Swivel Socket Adapters
With these in combination with a standard extension you can reach every lower spark plug from the wheel wells. A couple are straight shots and a couple are by feel but it is 1000x easier through the wheel wells than from above. You can easily get the front lower plugs in by hand by using a 2" straight extension on the spark plug socket. The angle you need to insert the spark plugs does not work with the wobble extensions, essentially completely horizontal. The wobble extensions do allow you to get the proper torque on the spark plugs, using a swivel sometimes makes this difficult.
The top spark plugs are very straight forward, unless you have a TVS supercharger. This is easily a 2 hour job however first time confusion with removal of the supercharger elbow turned this into a 9 hour adventure (definitely not the pizza and beer).
Get these:
Wobble Extensions
