Roush serpentine belt
6.2Canadian
Vancouver
Well I found the problem... The belt is kicking off at the power steering pulley during high rpm .. Roush has a kick plate they are sending me free of charge and says I shouldn't shred a belt again. I hope so!!
MTF
Celebration, Florida
Does Roush have a link to this item?
Be sure to post some pictures up, this sounds like a simple fix.
I'll keep my fingers crossed.
6.2Canadian
Vancouver
I'm not to sure about the link, I just called them and explained my issue and they told me they will send a part out to my roush dealer and have them install it at MY expense ...
I will post pics once it's installed.
6.2Canadian
Vancouver
MTF it's done you have an email ? I have some pics
decoste77
I had the same problem I picked up an 8 rib belt from Oriellys that matched the same length I think it was 124'' or 126'' then just cuts slice in it and tor the two ribs off, simple $35 fix until the roush belts showed up, it worked flawlessly believe it or not cheap way to get back on the road.
