Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford Raptor Engine Discussion and Performance Mods-6.2 Liter V8 [GEN 1]
Question about SCT Livewire...
This is a discussion on Question about SCT Livewire... within the Ford Raptor Engine Discussion and Performance Mods-6.2 Liter V8 [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
Hello Raptor buddies. I'm new here. I have a 2014 Raptor and have a SCT Livewire TS 5015 (not the ...
Sponsored By: GotExhaust
Old 11-18-2017, 05:02 AM   #1 (permalink)
Junior Member
Question Question about SCT Livewire...
Hello Raptor buddies. I'm new here. I have a 2014 Raptor and have a SCT Livewire TS 5015 (not the 5015P, not sure if there's a difference between them). But I have a couple of questions:
1)I plugged in my Livewire in my raptor to only remove speed limiter and I also put a 4.10 gear ratio. Everything else I left stock. I went to go test it out to see if the speed limiter was removed. It was, but when I was hitting about 120 in 6th, it sounded like it was about to reach the end of the gear but felt like it still had more in her. Should I change the gear ratio or rpms or something?
2) can anyone explain to me what each tune option does in the programming settings?
3) I broght my Livewire back in 2015 for my 2000 Ford Explorer. I used it just to remove the speed limiter. I was reading somewhere that the first car I use the Livewire on, it's locked to that car. Is this true? Because I want to reset my raptor back to stock but afraid that it's going to put a explorer setting in my raptor.
Sorry for the confusion guys, any little helps. Thank you!
Edit: The tune options are Tire Revs/Mile; Rev Limit DRV; Rev Limit NEU; Idle Speed DRV; Idle speed NEU. Anyone know what these do?
si_raptor is offline   Reply With Quote
Old 11-18-2017, 05:14 AM   #2 (permalink)
waddellw's Avatar
When you load the raptor tunes on the SCT and load it into the truck it should save the settings automatically. Going 120 the truck should not be limiting out, although the tires WILL NOT take those speeds and have a risk of blowing out and leaving you without a truck at minimum and potentially with serious injuries or death. I ran 120 (on an undisclosed closed course) and the truck was super unstable and that was a 1 time run, maybe your tires are better but listen to the tire guidelines, I'd set the limiter to 110 or so, and stock rear gear should be 4.10 from the factory so I don't understand changing that gear.
Best of luck man, I hope it all works out for you!
Edit: when you loaded your tunes did it say anything about saving the stock tune or how did you do it?
waddellw is offline   Reply With Quote
Old 11-18-2017, 12:18 PM   #3 (permalink)
Junior Member
very true i didn't think of it. it was a one time thing and thats it. and yes it saved thank god.
Old 11-22-2017, 03:03 PM   #4 (permalink)
Tires - keep in mind that is typically a continuous rating also accounting for 100 plus degree asphalt.
Agreed need to be safe and account for things, such as age and condition of tires, people/things around you, response times, etc.
A few short runs on an open straight stretch it isn't like as soon as you exceed the tire speed rating it's going to pop, but keep in mind at those speeds the slightest thing going wrong can compound and be disastrous.
Gen1 vs Gen2 - Depends on the day!
2014 Black Screw, 2017 Avalanche Screw
gwpfan is offline   Reply With Quote
Tags
2014 raptor, livewire, sct
SCT X3? or LiveWire? BubbaRaptor Ford Raptor Engine Discussion and Performance Mods-6.2 Liter V8 [GEN 1] 14 02-16-2016 10:23 AM
SCT Livewire TS question regarding backup camera BAJASVT Ford Raptor Engine Discussion and Performance Mods-6.2 Liter V8 [GEN 1] 11 05-30-2014 02:11 AM
New! SCT Livewire TS 5star 5 Star Tuning 23 12-26-2012 11:55 AM
Ford livewire TS gbrown27 Ford Raptor Engine Discussion and Performance Mods-6.2 Liter V8 [GEN 1] 7 09-29-2012 12:58 AM
Sct livewire tuner 11raptor6.2 Ford Raptor Engine Discussion and Performance Mods-6.2 Liter V8 [GEN 1] 1 03-01-2012 11:39 AM
