RaptorN/Abuild
- Joined
- Jul 23, 2015
- Posts
- 70
- Reaction score
- 31
Hey guys. I was thinking about installing the s675 package from livernois
https://www.livernoismotorsports.com/product/LPP0104107
I already have the whipple, fuel pump, cams l, and injectors. So all I would need is the studs, heads, and oilgears. Would the stock pistons and rods hold up to that 650 hp? Or should I go with the 6.6 stroker short block which already has the upgraded pistons, rods, and crankshaft and all I would need to get is the heads. The reason I was thinking about the first option is the money I would save by already having the whipple cams fuel pump and injectors I could spend on a upgraded King 2.5 coil overs. I talked with a guy from livernois about the first option and he said the motor would be good for 800 crank hp. My budget is about 15k. What do y’all think?
