put up your dyno results
justinb491
Naperville, Illinois
Our numbers are pretty close but I am running a 69mm pulley and the bigger lower pulley, stock roush tb and not dyno tuned. Just the tune Justin sent me. I will try and grab the 65mm TB and see if that can get me closer to the 500whp mark. That is my goal as well and want to do it without adding headers.
Thanks for the info.
For the guys wanting dyno info I have Vbox numbers at my elevation for 0-60, 1/8, 1/4 for a 2017 load supercrew and my truck run right after.
What Boost are you seeing? I right at 10lbs. It certainly woke the truck up. The throttle body was a great addition, super throttle response.
justinb491
Did your boost go up at all with the 65mm? I went from 8# with 69mm pulley to 10# with the bigger lower pulley.
Best place to buy 65mm? Your truck would go to 12-13# with a lower.
Boost didn't change until I swapped the pulley. Throttle body just improved throttle response and I'm sure it helps with flow
Hedges4
Central IL
Hellion Twin Turbo with 7 psi gates and bassani catless mid pipe.
Can't find the dyno sheet, but 520 RWHP and 537 RWTQ! :)
biturbomg
Sounds great! GLWS. Just tweaked the intake a bit so plan to have a new dyno update in the next few weeks.
92,817
56,075
Arizona Free
