reaper1441
- Joined
- Feb 4, 2018
- Posts
- 350
- Reaction score
- 206
I've tested this style of oil cooler extensively on other engines on track. Its a street setup and not ment for high stress situations. (oil to liquid coolers that is) Its primary benefit is getting the oil up to temp quickly in a street car without having to resort to a thermostatically controlled oil cooler. Which is what we do on most track cars that see street time to prevent them from over cooling the oil. The oil cooler doesn't actually see oil until 190* with a thermostatically controlled sandwich plate. Separate systems drastically reduce the chance of heatsoaking the entire system. Also not all cores are the same. Especially when comparing mishimoto to something like a setrab core. Also use aeroquip fitting whenever possible.
