Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford Raptor Engine Discussion and Performance Mods-6.2 Liter V8 [GEN 1]
No boost from supercharger.
This is a discussion on No boost from supercharger. within the Ford Raptor Engine Discussion and Performance Mods-6.2 Liter V8 [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
I have a roush supercharger and It used to be instant boost when I would take off in the morning ...
Like Tree1Likes
  • 1 Post By The Macf
Sponsored By: GotExhaust
Old 03-19-2017, 05:12 PM   #1 (permalink)
Junior Member
Default No boost from supercharger.
I have a roush supercharger and It used to be instant boost when I would take off in the morning but now I have no boost unitil it warms up for a few minutes. I pulled the charger and install a new bypass valve actuator and the same thing is still happening. I had a issue with my battery going dead over and over again and after I finally got that figured out multiple shop visit so no one could figure it out. It was my pigtail at my trailer lights were shorting out. Now I'm having this issue and I don't know if it's messed up the computer or what but it doesn't seem like it could have anything to do with the supercharger boost? Has anyone ever had this problem with not having any boost until the vehicle is warmed up in the morning . After it is warmed up it runs perfectly normal until it sits for about five hours and then the cycle of not having any booze starts again.
burnssj83 is offline   Reply With Quote
Old 03-19-2017, 06:49 PM   #2 (permalink)
MTF's Avatar
MTF
Any error codes from a OBDII scanner?
I can only think of one thing, the Tranny has thermostat that will prevent 100% torque until the tranny hits 175 degrees. Could be an issue with that being stuck or faulty.
Whipple 700+ HP Upgrade Package, Oil and Fuel pump upgrades, Custom Deavers +2 Rear Springs, Axle Exchange Driveshaft, Rogue Racing Traction Bars, Hellwig rear sway bar, Pace Edward electric bed cover with remote, Pop & Lock Tail Gate lock, Mud Flaps, Window Rain Guards, EZ Down Tailgate, Bed Rug,
Future Installs: Brembo Brakes 15" Gran Turismo
MTF is offline   Reply With Quote
Old 03-19-2017, 07:30 PM   #3 (permalink)
Junior Member
It does shift weird until I start seeing the boost. I was just thinking that the computer was confused because it is tuned for boost? I'll look into this. It has died twice when I have pulled up to a stop light also. Maybe my transmission fluid is low I'll check. I was also thinking maybe the throttle body had something to do with it because the line to the boost actuator is right behind the throttle body?
Old 03-19-2017, 10:18 PM   #4 (permalink)
MTF's Avatar
MTF
Without readings from a scanner and a data Log, it's really hard to make a judgment on what is going on.
You may have to find a Tuning shop or Ford Dealer that has done a few Roush Raptors or knowledge of them at best.
Old 03-19-2017, 10:31 PM   #5 (permalink)
Junior Member
Unfortunately there are not any shops here like that. Do you know if I can unhook the lower vacuum line to bypass actuator that goes to the air intake to put less pressure on the bypass valve?
Old 03-20-2017, 01:25 AM   #6 (permalink)
MTF's Avatar
MTF
These are questions that you need to ask Roush.
I do know that Whipple sometimes will use different spring strengths for the bypass valve.
But those are modified setups beyond the Whipple's recommendations.
Old 03-20-2017, 02:28 AM   #7 (permalink)
The Macf's Avatar
What side of the state are you on?
The Macf is offline   Reply With Quote
Old 03-20-2017, 12:35 PM   #8 (permalink)
Junior Member
I'm in the middle closer to Spokane than Seattle.
Old 03-21-2017, 01:54 AM   #9 (permalink)
The Macf's Avatar
yeah, might be worth a trip over the pass just to get some one to look at it. I think the big Issaquah dealership is Roush certified.
MTF likes this.
More BOOST!! justinb491 Ford Raptor Engine Discussion and Performance Mods-6.2 Liter V8 [GEN 1] 27 01-25-2018 10:01 AM
2017 Raptor Boost (PSI) and boost gauge MJslasherADMIN Ford Raptor Engine Discussion and Performance Mods - 3.5 Liter EcoBoost V6 [GEN 2] 38 04-13-2017 10:23 AM
Whipple 20 PSI Boost Gauge and Supercharger special offer!!! [email protected] Ford Raptor Engine Discussion and Performance Mods-6.2 Liter V8 [GEN 1] 2 11-13-2015 12:59 PM
Eco boost raptor?!? Djones632 Ford SVT Raptor General Discussions [GEN 1] 60 04-21-2014 06:13 PM
Eco-Boost gets 32mpg... Hockster Ford Articles, News and Media Reviews 0 05-13-2011 03:53 PM
