AlbertaRaptor
- Joined
- Oct 30, 2011
- Posts
- 116
- Reaction score
- 38
Well as some of you may be aware I am one of the few lucky guys to have hydro-locked a 6.2l Raptor.
Long story, stupid moment, never going to happen again.
Here's why:
If you remove your headlight and look behind it you see this:
Too damn low and catches all the splash from around the wheel.
I cut the factory inlet here:
Attached a 3" coupling made of rubber like so:
Then I rigged up a 3 inch diameter by 26" piece of PVC attached to a 90 degree bend seen here in this crappy photo. I never should have rested it in the air box for the photo , it was just sitting there. It is not attached:
Drilled some drainage holes just incase the water makes it into the tube:
Wrapped it in foam by butchering a humidifier filter and threw on some duct tape for the Red Green fans out there. I wanted to cushion the movement in the inner fender and I wanted to block partially the ability of those holes to suck in mud and debris while allowing water to drain out of the tube before the air box:
I then slid the two parts together using that coupling:
So it looks like this from behind the headlight now:
If you look down the fender from the top side with the SVT vent removed it looks like this:
And with the vent back in place:
No snorker exists, it may not be pretty, but it does work fine and pulls air from a much higher source.
No adverse effect on power or economy or anything. You wouldn't even know it's there.
BUT...
I'm not blowing up another 6.2
Jeff
Here's why:
BUT...
Jeff
