Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford Raptor Engine Discussion and Performance Mods-6.2 Liter V8 [GEN 1]
HELP- ending ticking noise!
This is a discussion on HELP- ending ticking noise! within the Ford Raptor Engine Discussion and Performance Mods-6.2 Liter V8 [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
Sponsored By: GotExhaust
Old 10-09-2017, 08:29 AM   #1 (permalink)
Junior Member
Default HELP- ending ticking noise!
Hi guys,
I have an off engine ticking noise coming from the engine bay and I canít figure out what it is. It is from a 2013 raptor, it is very slight and you canít really hear it when your outside the car, I can only really hear it from the inside. It is a high pitches tick and gets faster when you speed up (and the pitch rises slightly).
I have checked the tires multiple times and nothing is stuck in them, does anyone know what it could be? I have had a couple of people say it might be injectors or a pressure valve but I want to make sure, my truck is still under warranty so hopefully it can be covered.
Thanks in advance!
hmsbmk is offline   Reply With Quote
Old 10-09-2017, 01:36 PM   #2 (permalink)
John813's Avatar
I think I had the same tick on my first Raptor. Never figured it out.
Your makes the noise in drive and park/neutral?
I could hear mine very clear when the hood was open and parked(duh)
John813 is offline   Reply With Quote
Old 10-12-2017, 10:15 PM   #3 (permalink)
IamCanadian's Avatar
Check the EVAP Purge Valve.
Banks Ram Air CAI, 35x12.5 x 17 KO2, Hood Graphics, Bed side Graphics, Borla touring Cat- back, Mid Perch, SVC Tune
IamCanadian is offline   Reply With Quote
Old 10-13-2017, 09:58 AM   #4 (permalink)
BenBB's Avatar
Canister Purge Valve (CPV) is a common ticking noise, it's right between the intake and the firewall so you might hear it more from inside than outside with the hood closed. With the hood open and the engine running you should be able to hear it pretty clearly, moreso on the driver's side. If that's not it, could be a blown speaker dragging? You could play with the balance/fade and see if it changes at all...
BenBB is offline   Reply With Quote
Old 10-14-2017, 06:23 PM   #5 (permalink)
MGD
Banned
Thought about injector noise? If they have quite a few miles, try running 2 bottles of Chevron with Techron through a full tank of gas. You might fix, or rule that it would be valvetrain noise. I have read of noisy vale trains on these 6.2s.
Link -
6.2 intermittent valve train ticking noise at start up ??????????????
MGD is offline   Reply With Quote
Old 10-15-2017, 03:41 PM   #6 (permalink)
Crash33's Avatar
Spark plug wire?
Alter ego of whoisbigman... (I'm at work today)
Crash33 is offline   Reply With Quote
Old 11-30-2017, 11:39 PM   #7 (permalink)
I had a very similar noise, changed the evap purge valve and it fixed it
aschiller98 is offline   Reply With Quote
Old 12-04-2017, 09:26 PM   #8 (permalink)
Go out at night and look under the hood while itís running. It could be a spark plug wire or a coil arcing. Youíll see a nice blue strobe light somewhere, if it is. I had both at the same time.
Makes a nice clicking or popping noise.
Brandon### is offline   Reply With Quote
6.2 intermittent valve train ticking noise at start up ?????????????? RV67 Ford Raptor Problems and Questions Forum 147 11-29-2017 03:16 PM
HELP- Engine problem ticking noise. hmsbmk Ford Raptor Engine Discussion and Performance Mods - 3.5 Liter EcoBoost V6 [GEN 2] 8 10-09-2017 07:23 AM
Clicking/Ticking Noise on Startup svt_ivan Ford Raptor Audio/Video/Electronics Forum [GEN 1] 2 01-18-2017 10:35 AM
Ticking humming noise in transmission CamoTyme44 Ford Raptor Problems and Questions Forum 5 01-05-2016 06:23 PM
Omg my engine has a ticking noise at start up !1!1!1!1! The Tank Ford Raptor Problems and Questions Forum 15 05-15-2012 04:50 PM
