Grinding sound on cold startup
Geo_Tactical
Idaho
Ever since I bought my truck, on the first start of the day, about 2-3 seconds after ignition I hear sort of a grinding noise that lasts for just a second. Almost sounds like something is moving into position, but making noise as it does so. Since it's done this from day 1 I doubt it's a problem, but was wondering if anyone could tell me what they think it is?
Kevin
RC51TOFUMAN
in Thee OC
Kevin
Mine does the same
Sent from my SM-G920V using Tapatalk
CoronaRaptor
CANADA
You guys think it's from the engine compartment? Or do you think it's the blend motors behind the dash?
IamCanadian
Barrie, ON
I have the same issue. The dealer change the AC compressor but I believe that the clutch unit is still the same. If I started it with out the AC on the issue disappears.
Dane
Littleton, CO
Mine has always done it. I've always thought it sounded like the starter. I think it only happens on auto-start, but I'm not positive.
