stefanwerner
- Joined
- Dec 26, 2014
- Posts
- 6
- Reaction score
- 5
I came across a number of posts with folks making custom intake tubes extending back towards the SVT vent in the fender to prevent water ingestion. I did things a bit differently and thought I'd share the results:
4" to 3" coupler to prevent any cutting, this does create a tight seal:
Water relief cuts (there are a few more along bottom of the inlet tube):
View from headlight area (90 degree elbow attached to coupler, hole cut through foam barrier for PVC pipe):
Water-resistant pre-filter (notice I've cut the 3" PVC at an angle near the vent for clearance):
Inlet with pre-filter installed:
Final result:
Final result:
