6.2 sparkplugs ?
40oz
Sorry for the double post, found this more recent spark plug thread.
What is the trick to getting the two plugs behind the shock mount? 1 on the driver and one on the pass? I could not get my hands in there and start the plug socket.
biturbomg
Non Supercharged 50K is a good idea. Ford says 100K...
Supercharged I would do 20-25K
JimIII
Jim what plugs/gap and cost for all 16 and is 3hrs normal time for install for a tech or can it be done in drive way in that time.
Thanks
JimIII@JDM
New Jersey
Camperguy
Masshole
Curious why no one is running the Denso Iridium TT PT#ITV20TT 4719 .I have run them in everything . A very nice salesman at AutoZone gave me them at cost for Veterans day! Usually $7.99 Ea. The longest I have run any plug is 30k and these plugs maintained factory set gap with no show of wear. Thats why I went to them.
Bill
EricM
OHIO
I prefer NGK. Any of the fine wire iridium plugs are good though.
Camperguy
Masshole
It typically takes us almost 3 hrs to change the plugs on a Roush SC truck. It's a little technical but could be done in your driveway, it does not need a lift or anything. We use the NGK 6510 plugs and gap them to .030"
NGK-6510 Spark Plug 6510 For the Ford Raptor Truck 6.2L - JDM Engineering
Is the .030 gap to prevent flame blowout? I was curious if the coils on the Raptor work like the standard DIS coils , where one fires center electrode to ground and the other ground electrode to center?
Would a voltage stabilizer using capacitance/reactance to reduce voltage noise and fluctuation?
Thanks Bill
