debate
Anyone know if there's an estimate of how many hours it will take a technician to change all 16 sparkplugs on a Raptor?
Thanks!
Thanks!
bout 2.8hours.
Why not change out yourself?
Question, it the 6.2 like the old 5.4, where the plugs are in a hole about 10" deep. Also do they still have the 100,000 mile service interval?
I know with the 5.4 the plugs often broke on removal.
actually the 04-08 5.4 changed the service interval to 60k to try and prevent so many from breaking. In the last year they also redesigned the plug so that they are no longer suppose to break. In 08 1/2 they had another spark plug change where the ground electrode is threaded all of the way down and changed the size of spark plug socket again. I haven't attempted to pull out the one on 6.2 yet but I'm sure they are fully threaded down. The ignition coil sits on 1 spark plug then you have a wire that goes down to the second plug. They do go down in the hole a few inches I believe still with the modular engine design I don't see that going away.
Damn it Ruger.....I have 16 Split Fires to use on mine with the hopes of gaining 30 HP !!
