Andrew72
- Joined
- Apr 24, 2018
- Posts
- 13
- Reaction score
- 8
Sorry if this has been asked before. Have read through as many similar posts as I could and didn't seem to find the exact same issue/solution. Thanks for any responses.
2014 Raptor 6.2L with 49,675 miles on it. I recently picked it up used. After getting onto the freeway with a good amount of acceleration, noticed a slight ticking noise when idling and driving at low speed with the passenger window down. Noise seems to be coming from top passenger side of the engine. This noise is not only at start up and makes the noise no matter how warm/long the engine has been driven. I did not notice the noise before hand. Cannot notice the noise with the windows up. Almost sounds like something small is stuck on the tire and making a noise each rotation, but it has to do with or ontop of the engine, when parked idling etc. Seems to slightly increase in speed when pressing gas pedal. After driving some more and using more power the noise becomes more prevalent. Anyone have any ideas what it might be? Lifter noise, Spark plug, Canister purge valve/EVAP purge valve, fan? Thanks, Andrew
