Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford Raptor Engine Discussion and Performance Mods-6.2 Liter V8 [GEN 1]
2011 Raptor - Problem with Whipple Stage II Going Lean
This is a discussion on 2011 Raptor - Problem with Whipple Stage II Going Lean within the Ford Raptor Engine Discussion and Performance Mods-6.2 Liter V8 [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
Hi everyone. Have a 2011 6.2 Raptor that we installed a Stage II Whipple kit on. The truck is currently ...
Sponsored By: GotExhaust
Old 12-06-2016, 06:11 PM   #1 (permalink)
Junior Member
Default 2011 Raptor - Problem with Whipple Stage II Going Lean
Hi everyone. Have a 2011 6.2 Raptor that we installed a Stage II Whipple kit on. The truck is currently at the dyno tuner getting a custom tune put on. The tuner called me and stated that the truck is going lean above 3500 rpm. He has tried everything computer-wise, we also swapped the fuel pump and fuel pump driver and still no go. We checked to ensure the correct injectors were installed and they are. I have an email into Whipple but wanted to check here and see if anyone encountered something like this in their trucks.
Thanks
radelow is offline   Reply With Quote
Old 12-06-2016, 10:07 PM   #2 (permalink)
Whats the fuel pump duty cycle at? Whats the injector duty cycle at?
CarmanKyle is offline   Reply With Quote
Old 12-07-2016, 01:25 PM   #3 (permalink)
MTF's Avatar
MTF
Going lean can be caused by quite a few mechanical issues.
Fuel pump would not be an issue, even with the Stage 2
While I did upgrade my fuel pump, it turns out it's not really necessary unless you're going beyond the stock Whipple Stage 2 setup with Whipple's Tune.
1) O-rings on the manifold is the number one cause.
2) Vacuum leaks from any of the hoses and hose connection.
3) O2 sensors
A complete fuel TRIM reading is the only way to tell. Whipple will want that info as well!
Did the Tuner say which bank or is it both 1 and 2
Keep us updated.
P.S. You may want to check the fuse 27 issue
---------- Post added at 01:25 PM ---------- Previous post was at 01:21 PM ----------
Duty cycle is not the way to determine fuel flow on these trucks.
Fuel rail pressure is the correct way.
Whipple 700+ HP 800+ in the works, Oil and Fuel pump upgrades, Custom Deavers +2 Rear Springs, Axle Exchange Driveshaft, Rogue Racing Traction Bars, Hellwig rear sway bar, Pace Edward electric bed cover with remote, Pop & Lock Tail Gate lock, Mud Flaps, Window Rain Guards, EZ Down Tailgate, Bed Rug,
Future Installs: Brembo Brakes 15" Gran Turismo
MTF is offline   Reply With Quote
Old 12-12-2016, 02:05 AM   #4 (permalink)
Junior Member
Hi everyone. We ended up swapping out both the fuel pump and the driver module and everything tuned up correctly. Strange that they were partially broken (one or both)... Anyway truck runs perfect and is a complete BEAST.
Thanks!
Old 12-29-2016, 11:17 AM   #5 (permalink)
5150_Raptor's Avatar
Junior Member
Sounds like you need to run a bap
Sent from my SM-G930V using Tapatalk
5150_Raptor is offline   Reply With Quote
Raptor Lean accely Ford Raptor Problems and Questions Forum 158 10-09-2017 03:58 PM
2011 Camaro SS Whipple, and much more.. cpetes Vehicles For Sale 2 05-26-2016 06:20 PM
Thinking about mounting a Stage 2 Whipple kit, looking for information. ivo1.cox Ford Raptor Engine Discussion and Performance Mods-6.2 Liter V8 [GEN 1] 10 09-01-2015 04:40 PM
2011 SVT Raptor Gearshifting problem sean ralph Ford Raptor Problems and Questions Forum 1 11-16-2014 10:45 AM
Livernois Built 2011 Raptor - Whipple 2.9 & Livernois Cams - VIDEO Livernois Motorsports Livernois Motorsports 29 02-24-2014 08:54 AM
